Anonymous
Long distance design
Hi,
When i configure ISL beetween two HP 8/40 ( B5100)  with LD mode , i have this message.
Did i need to disable DLS ? if yes , why ?
Regular Contributor
Re: Long distance design
Hi Berni,
which routing policy do you have?
If you have exchanged base rp you can not disable the DLS.
Try to configure the Long Distance with CLI.
Regards
Ralf
Kind Regards
Ralf
Valued Contributor
DLS is enabled by default when using exchange-based routing and to disable it you'll have to change to port-base routing (which is an offline operative) . I do not know why it recommends to disable DLS with CR, what is current FOS release? I would rather disable CR than disable DLS.
Rgds
