Turn on suggestions
Showing results for
06-02-2016 06:15 AM
Hello,
We plan to upgrade the M5424 from FOS 7.0.1 to 7.4.1b. The Brocade switch is connected in access gateway mode to MDS9509 NX-OS 6.2(3).
I didn't find any interoperability matrix.
May you help me?
06-02-2016 07:03 AM
Sophia,
attached is latest attached matrix May 2016.
06-02-2016 07:46 AM
Hi Antonio,
Thank you for the reply.
I didn't find my information in the pdf file.
the M5424 is in AG mode
06-02-2016 08:37 AM
Sophia,
is the Cisco a Old MDS 9509 Chassis ? I ask because you wrote ->NX-OS 6.2(3)
last time i worked with Old Cisco MDS, i know with OS 5.x
It show from a new Matrix Guide, that Old MDS as be removed, but if the 5424 is set in AG Mode and on MDS NPIV is configured, then you should be able 99% without a problem in newest FOS Release to Interop with the MDS.
is the 5424 currect in productive environments with the MDS ?
06-02-2016 08:40 AM
The M5424 is in a DELL M100 chassis and is connected to our core SAN (MDS9509) in AG mode.
So you validate that FOS 7.4 will be compatible with MDS9509 6.2(3)?
06-02-2016 09:31 AM
I'm confident that should work, but cannot give you any warranty.
I would suggest to Uprade one step Release at a time first to 7.1.x and monitoring if all work fine for a couple of day, then proceed with next FOS Release 7.2.x and so on.
If you have a doubt, then open a TAC with Brocade.
06-02-2016 09:43 AM
Thank you for your feedback.
I will upgrade only one switch first and check SAN health.
Have a nice day
