New Contributor
Accepted Solution
Inconsistent switches amount from 2 APIs
Hi,
Can you help me understand why when I use the following API to get all the fcswitches, I get 26 switches(using the key value):
rest/resourcegroups/All/fcfabrics/[fcfabric-id]/fcswitches
But when I use the following API to get all the fcports, I get 31 switches(using the command value):
rest/resourcegroups/All/fcswitches/[fcswitch-id]/fcports
How come that the first API gives back 26 switches and the second API gives back 31 switches?
Am I missing anything?
Thanks for the help.
Frequent Contributor
Re: Inconsistent switches amount from 2 APIs
Not that I know the exact answer, but...
Do you have VF and/or FCR in your environment? Or maybe some switches configured as AG?
New Contributor
Hi,
Yes. I have exactly 5 switches that are configured as AG.
Can it be related?
New Contributor
I've checked it.
That's exactly the switches that are missing.
Thank you!
That makes sense. From the "fabric" point of view these "switches" are not switches, as they do not act as a separate domain etc... But otherwise they are discoverable as individual switches and could be polled for properties, stats and so forth... Good that this helped!
