Anonymous
ISL trunking problems
Hi all
My switch model is brocade 5000 with FOS 5.3.0
I connect 2 fiber between two switches, and the trunking is listed on license
Two ports were found showing as E-port
On web tools
But in each port details, the button of both Enable trunking and disable trunking is dimmed on the FC-tab
And no trunk links on switch admin page - trunking tab.
Any ideas ?
External Moderator
Re: ISL trunking problems
RyanLi,
--->>> Any ideas ?
you need a Trunking License before you can use trunking.
check trough the CLI with the command "licenseshow" to see wich License are installed.
TechHelp24
TechHelp24
Anonymous
Hi
I have checked on web tools --license
trunking is on the list
External Moderator
If a trunking License is Installed ( both switch ) , your must before can use trunking config this trough the CLI with the command "portcfgtrunkport"
for details see in the CLI Manuals.
TechHelp24
TechHelp24
