Anonymous
ISL conection betwen a switch DIRECTOR 12000 Silworm and a 16 ports FC san switch
Hi!
Anonymous
Re: ISL conection betwen a switch DIRECTOR 12000 Silworm and a 16 ports FC san switch
hello,i am new to brocade, but had something similar happen on mcdata a few months ago. i ended up having to call for support - they had to change a port flag setting, if i remember correctly.
Anonymous
Hi,Regards in advanced
External Moderator
GODMAN, you must first whit the command "configure" select the correct PID format of both switch here option "1" otherview is not possible to connect the 2800 whit 12000. BTW, please note that Trunking is not supported in the 2800.
TechHelp24
