Anonymous
I can not show my switches in my web browser
Hi, experts:
Anonymous
Re: I can not show my switches in my web browser
I would try upgrading to a newer version of Java.What browser are you using IE or Netscape/Mozilla?
Anonymous
My Web browser is IE 6.0. Thanks.
Anonymous
Is the check box checked to integrate the java plugin with IE?Did you try upgrading your version of java?
Anonymous
The check box is checked.So I suppose the problem might have something to do with the web browser or the switches themselves.
Anonymous
The problem is solved by using the latest JRE (JRE 1.4.2).Thanks a lot, rsingler.
