Anonymous
How to stack switches (Not sure of the correct term)
I currently have two 3200 Silk worm switches and received 2 3250 so that I can exten my fabric past the 8 ports... Can some one direct me to instructions on how to add additional switches?
Anonymous
Re: How to stack switches (Not sure of the correct term)
You're wanting to ISL the switches together. The easiest way, if the new switches have no zone database on them, is to just plug them into the old switch and then power them up.You can find all sorts of documentation in the library here on Brocade Connect. Let us know if you need any more help.
