Regular Visitor
How do unconfigure an ISL Connection??
Hello,
I am in need of unconfiguring ISL Connections.  I have 2 fabrics, in each fabric I have 1 6505 and 1 G620. Ports 0/4 are being used on the 6505 SAN and Ports 19/23 are used on the G620 SAN.  I would like to remove the 6505 from the fabric.  What steps would I take to accomplish this?
Thanks so much for any info that can be provided..
Broadcom Moderator
Re: How do unconfigure an ISL Connection??
The command is "portcfgeport 0/4 0" will disable the port 0/4 from becoming an E port(ISL). To reverse this use the same command with a 1 at the end to enable the port as an E port again.
See the FOS command reference for full explanation.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
