Occasional Contributor
Accepted Solution
Help brocade 4424 - Configure SAN Access Gateway Mode
I have a brocade 4424 installed on the blade dell, I have a storage, the switch is in Access Gateway Mode, I connected the GBig in the storage and the FC cables in switch 4424, but I do not get a link, how to configure the switch? I've read a lot, but I do not have much experience with these connections and switch. Tanks.
External Moderator
Re: Help brocade 4424 - Configure SAN Access Gateway Mode
@cadete
are the internal Port Blade mapped to correct External Port ?
post the output of
ag --mapshow
what type of storage you want to connect ?
what is the FOS release ?
TechHelp24
Thank you for your attention.
The output ag-mapshow in the picture is attached.
I will connect a lenovo storage.
FOS Version v6.2.0c
External Moderator
@cadete
I wrote, Post output and not PIC ( from command line ) copy and paste here
a PIC 4424_1 from you first Post yesterday, show the switch as offline.
the switch must be set in enable "switchenable"
TechHelp24
[ Edited ]
follows output switchshow and ag --mapshow:
SW4424:admin> ag --mapshow
N_Port Configured_F_Ports Current_F_Ports Failover Failback PG_ID PG_Name
0 15;16 None 1 1 0 pg0
18 3;4 None 1 1 0 pg0
19 5;6 None 1 1 0 pg0
20 7;8 None 1 1 0 pg0
21 None None 1 1 0 pg0
22 11;12 None 1 1 0 pg0
23 13;14 None 1 1 0 pg0
SW4424:admin> switchshow
switchName: SW4424
switchType: 61.0
switchState: Online
switchMode: Access Gateway Mode
switchWwn: 10:00:00:05:1e:d9:ff:fe
switchBeacon: OFF
Area Port Media Speed State Proto
0 0 id N4 No_Light
1 1 cu 4G No_Sync Disabled (No mapping for F-Port)
2 2 cu 4G No_Sync Disabled (No mapping for F-Port)
3 3 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
4 4 cu 4G No_Sync
5 5 cu 4G No_Sync
6 6 cu 4G No_Sync
7 7 cu 4G No_Sync
8 8 cu 4G No_Sync
9 9 cu 4G No_Sync Disabled (No mapping for F-Port)
10 10 cu 4G No_Sync Disabled (No mapping for F-Port)
11 11 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
12 12 cu 4G No_Sync
13 13 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
14 14 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
15 15 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
16 16 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
17 17 id N4 No_Sync Disabled
18 18 id N4 No_Light
19 19 id N4 No_Light
20 20 id N4 No_Light
21 21 id N4 No_Light
22 22 id N4 No_Light
23 23 id N4 No_Light
switchName: SW4424
switchType: 61.0
switchState: Online
switchBeacon: OFF
0 0 id N4 No_Light
1 1 cu 4G No_Sync
2 2 cu 4G No_Sync Disabled (N-Port Offline for F-Port)
4 4 cu 4G No_Sync
5 5 cu 4G No_Sync
6 6 cu 4G No_Sync
7 7 cu 4G No_Sync
8 8 cu 4G No_Sync
12 12 cu 4G No_Sync
17 17 id N4 No_Light
19 19 id N4 No_Sync Disabled (Initiator/Target connected to N-Port)
20 20 id N4 No_Sync Disabled (Initiator/Target connected to N-Port)
Solved, it was necessary to connect the fibers with another FC brocade switch.
0 0 id N4 No_Light
1 1 cu AN No_Sync
2 2 cu N4 Online F-Port 20:01:a4:ba:db:0c:ba:dc 0x010101
3 3 cu N4 Online F-Port 20:01:a4:ba:db:0c:ba:e9 0x010301
4 4 cu AN No_Sync
5 5 cu AN No_Sync
6 6 cu AN No_Sync
7 7 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:1d 0x010104
8 8 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:2a 0x010302
9 9 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:37 0x010102
10 10 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:44 0x010304
11 11 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:51 0x010105
12 12 cu AN No_Sync
13 13 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:6b 0x010106
14 14 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:78 0x010305
15 15 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:85 0x010103
16 16 cu N4 Online F-Port 20:01:a4:ba:db:0c:bb:92 0x010303
17 17 id N4 Online N-Port 10:00:00:05:1e:c6:64:08 0x010100
18 18 id N4 Online N-Port 10:00:00:05:1e:c6:64:08 0x010300
