Anonymous
Flash Module
I have a Brocade 300 8gb switch. i believe the flash module is failing. can i install a new blank flash module and recover the data off the switch? does anyone out there know how to fix this?
External Moderator
Re: Flash Module
No way.
If you are sure the CF is failed, you have to open a call with Brocade or you OEM Supplier if this is under maintenance, and replace the switch.
can you post more details about the error ?
TechHelp24
