Anonymous
Firmware upgrade 4900 and 7500 from V5.3.0 to 6.3.0d
Hello,
I need help to upgrade the F/W of Brocade SAN Switch 4900 and 7500 from V5.3.0 to 6.3.0d, below are the things I'm looking for.
  • The step by step procedure
  • Prerequisites
  • Backout Plan
Regards
Om
Super Contributor
Re: Firmware upgrade 4900 and 7500 from V5.3.0 to 6.3.0d
Such question was answer here in the community and diverse valuable Theads are available.
looking for "firmware upgrade" "fabric OS upgrade"  or "FOS upgrade" in the community
Anonymous
Thanks for the reply,
I'm unable to find the code upgrade process and prerequsites specifically for the mentioned switches, it would really great if you can provide some URL or PDF for the same.
thanks
Om
Super Contributor
Ok..
Are you in FICON or Open System Environments ?
Anonymous
Open System
Thanks
Om
Anonymous
As a general rule, you have to go 5.3x, 6.0.x, 6.1.x, 6.2.x, to 6.3.0x etc. I'd recommend reviewing the release notes for all versions prior to doing the upgrade. In addition  you'll also want to back up any and all switch configs prior to performing the updates.
Anonymous
Hi,
From 6.0.x you can go 1 step up.
Also do the FOS upgrade one Fabric at a time. First Fab-2 and see whether you face any Server HBA Firmware compatibilty issue or any other issue. then you do fabric-1.Some times you may have to face Server HBA Firmware issue or multipathing SW issue.Chekc the Brocade compatibilty matrix.
