New Member
Firmware download timed out. (0x23), after repair no firmwareupdate possible 6510switch
Yesterday i've started a firmware update on a brocade 6510 gen5 switch from v7.3.1d to v7.4.2c. The firmware update was very slow due to network issues (32-40kb/sec), and the firmwaredownload failed, It did a succesful repair, but after that every attempt to update the firmware fails.
Log failure:
hss-diag-7.4.2c-10
############################### [ 100% ]
Removing unneeded files, please wait ...
Firmwaredownload timed out.
Firmware download failed - Firmware download timed out. (0x23)
Aborting firmwaredownload now.
Firmwarecommit has started on the local CP. Please use firmwaredownloadstatus and firmwareshow to see the firmware status.
Validating the filesystem ...
IJMSAN2X6:admin> Finished removing unneeded files.
creating the old storage file
Repairing the secondary partition now.
Please wait ...
Repair on the secondary partition completes successfully.
IJMSAN2X6 login: admin
Password:
IJMSAN2X6:admin> firmwareshow
Appl     Primary/Secondary Versions
FOS      v7.3.1d
         v7.3.1d
IJMSAN2X6:admin> firmwaredownloadstatus
[1]: Wed May 30 08:22:56 2018
Firmware is being downloaded to the switch. This step may take up to 30 minutes.
[2]: Wed May 30 08:52:55 2018
[3]: Wed May 30 08:52:55 2018
[4]: Wed May 30 08:52:56 2018
The firmware commit operation has started. This may take up to 10 minutes.
[5]: Wed May 30 08:58:00 2018
The commit operation has completed successfully.
IJMSAN2X6:admin>
after the succesful repair i've tried to do the firmwareupdate again from another FTPserver which is also used for firmwareupdates, and the download also fails on several errors:
/bin/mv: cannot create regular file `/var/log/fwdl.log.save': Permission denied
wget: /var/log/wget.log: Permission denied
please advice how to repair this and restart a successful firmware upgrade
full log:
Server Name or IP Address: 10.106.40.210
User Name: patrick
File Name: /v7.4.2c/release.plist
Network Protocol(1-auto-select, 2-FTP, 3-SCP, 4-SFTP) [1]: 2
Password:
Server IP: 10.106.40.210, Protocol IPv4
Checking system settings for firmwaredownload...
Failed to access ftp://patrick:*******@10.106.40.210//v7.4.2c/release.plist
The server is inaccessible or firmware path is invalid. Please make sure the server name or IP address, the user/password and the firmware path are valid.
External Moderator
Re: Firmware download timed out. (0x23), after repair no firmwareupdate possible 6510switch
@patrick.de-jonge
reasons of 0x23 is Timeout error caused from FTP Server
most probable at 99,999% Switch LAN Port have different settings as the 6510 LAN management Port
check with the command "ifmodeset" on 6510 how the port is set.
make sure the 6510 is not behind to firewall and if necessary disable for short time.
it is not necessary to point to /release.plist
TechHelp24
Broadcom Moderator
There was a Brocade branded USB stick shipped with your 6510. When you find it, insert it in a computer, navigate to the firmware downloads on this site, and download the target FOS release onto the USB stick in the /firmware location. Insert the USB stick into your 6510. Perform the following steps:
Start a CLI session to the switch. Enable the USB, and make it visible to the switch;
usbstorage -e
Insure your FOS is in the right location:
usbstorage -l
firmware\ 408MB 2017 Mar 11 13:23
    v7.4.2c\ 408MB 2017 Mar 11 13:23
Download firmware from USB
firmwaredownload -U v7.4.2c
Use the absolute path if you have issues; /usb/usbstorage/brocade/firmware/v7.4.2c
After the FOS upgrade is completed, check the FW;
firmwareshow
Insure that the download shows complete
Disable USB
usbStorage -d
Now, where did you put that little USB stick from Brocade? You cannot use any USB stick, it must be the one that was shipped with your switch. If you can't find it, one may be ordered from your Brocade sales rep. Then, suggest you go fix your mgmt network issues.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
Broadcom Moderator
Hi Patrick,
the following is the key
"/bin/mv: cannot create regular file `/var/log/fwdl.log.save': Permission denied
wget: /var/log/wget.log: Permission denied"
So, the firmwaredownload command running as admin is not able to create files or do not have all the right to run correctly. And in this case we are using wget to get file from your ftp server, but we fail to even create log file.  The current failure have nothing do with ftp, but instead with the state of the switch after the repair was finish.  Are you able to share the complete log file from the failed firmwaredownload?
kind regards
Broadcom Moderator
You can always try as root to run firmwaredownload.
kind regards,
-martin
Member
We've managed to repair the firmware issue on the switch, the cause appeared to be a network issue during the firmware upgrade.
We're using OEM EMC/IBM switches which didn't came with the USB stick for the firmware, our sales representative in NL was so kind to send me one.
We've used the root user to do the firmwareupdate, but encountered a problem to logon as root, we've discovered that the default root userid is different on OEM EMC devices! After that we configured all the brocade devices with a non-default root password and ran the firmwareupdate successfully.
Thank you all for the quick replies and help, this topic can be closed.
