Anonymous
Firmware compatibility
I have two switches in my fabric; one with v6.1.1a the other is v5.0.1b. I want to know if I can add a third with v3.2.1c as a DR site over long wave fiber. Thanks for your help...
External Moderator
Re: Firmware compatibility
Refer the Release Notes FOS 5.x and 6.1.x for compatibility beetwen 3, 5, and 6 FabOS Release.
already in advance here the answer.
1
All zoning and fabric operations performed in a fabric with products running older versions of FOS
should be done via interfaces to products running the latest version of FOS. This is particularly
important for Brocade 3XXX series switches that do not support zoning configuration for newer
products.
TechHelp24
Anonymous
Thanks. Just what I was looking for...
