Turn on suggestions
Showing results for
06-28-2018 10:26 AM
Hello experts,
I would like to know which MIBs contains the information about FC-FC routing? the MIB table connUnitSnsTable, swSnLocalTable, fcFxLoginTable only have local attached port <---> switch port. Is there a MIB table about "lsanzoneshow -s"?
Thanks in advance!
