New Contributor
Accepted Solution
Disable arcfour/RC4 ciphers
Hello,
I'm trying to disable Arcfour cipher for SSH and i cant find a way to do this.
After some research i understand that is possible to configure the ciphers, starting with FOS 7.4.1... but Arcfour isn't showing as an available cipher? has it been deprecated and therefore disabled/removed by default?
How about FOS versions below the 7.4.1? is there a way to disable Arcfour cipher?
Thank you
Broadcom Moderator
Re: Disable arcfour/RC4 ciphers
Hello,
From FOS 7.3, the openssh server was updated and the less secure ciphers were removed.
The long term plans is to address this availability to disable unsecured services which is study for FOS 8.X. Can't do that in FOS 7.4.x
New Contributor
Tks Thierry.
