Occasional Contributor
Difference between supportshow and supportsave output
[ Edited ]
Hi All,
Please clarify me about what is the difference between supportshow and supportsave output in brocade SAN switches?
Regards,
Dhakshinamoorthy Balasubramanian
External Moderator
Re: Difference between supportshow and supportsave output
in summary, both command are diagnostic command which are required for diagnostic support.
both file are intended to use by Brocade Support to investigated error or issue
TechHelp24
Hi,
Which one have more diagnostic information?
Regards,
External Moderator
Supportsave
TechHelp24
Hi,
Can you elaborate supportshow and supportsave contains what are all the command output?
Regards,
External Moderator
for that you have to open a call with Brocade.
Keep in mind, Support or Maintenance Contract must be active
TechHelp24
Thanks.
Regards,
