Anonymous
Device tries to flogi to port, reject FLOGI as persistent PID is set on the Loop device
We have a 2498-24B SAN switch and whenever there is a power disruption or reboot one tape drive fails to log back in.  The port is disabled and the following warning is given, Device tries to flogi to port, reject FLOGI as persistent PID is set on the Loop device.
We have 2 tape drives attached to the switch and only 1 has this issue.
You can issue a portenable command and the tape drive will log back in.
We don't have the port ID bound for those tape drives but do have other WWPNs bound.
Has anyone come across this?
Anonymous
Re: Device tries to flogi to port, reject FLOGI as persistent PID is set on the Loop device
Is there a difference in the port configuration?? Pls post portcfgshow of the 2 switch ports where the tape drives are connected. I want to check if there is a difference in the config.
Whats the state of the port in switchshow, once you power cycle the library? Did you check with portflagsshow as to whether the port is stuck in some state of transition?
Thats all I can think of.
Anonymous
portcfgshow 14
Area Number:              14
Speed Level:              AUTO(HW)
Fill Word:                1(Arbff-Arbff)
AL_PA Offset 13:          OFF
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
Persistent Disable        OFF
NPIV capability           ON
QOS E_Port                AE
Port Auto Disable:        OFF
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
portcfgshow 15
Area Number:              15
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
NPIV capability           ON
QOS E_Port                AE
Rate Limit                OFF
Mirror Port               OFF
Credit Recovery           ON
F_Port Buffers            OFF
portflagsshow
Port SNMP      Physical   Flags
    0 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP ACCEPT FLOGI
    1 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP ACCEPT FLOGI
    2 Offline   No_Light   PRESENT U_PORT LED
    3 Offline   No_Light   PRESENT U_PORT LED
    4 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
    5 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
    6 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
    7 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP ACCEPT FLOGI
    8 Offline   No_Light   PRESENT U_PORT LED
    9 Offline   No_Light   PRESENT U_PORT LED
   10 Offline   No_Light   PRESENT U_PORT
   11 Offline   No_Light   PRESENT U_PORT LED
   12 Offline   No_Light   PRESENT U_PORT LED
   13 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
   14 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP ACCEPT FLOGI
   15 Online    In_Sync    PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
Anonymous
Hi if your device is configured for persistent PID then you can configure your switch to enable WWN based PID assignment, as per manual:
Enabling automatic PID assignment
NOTE
To activate the WWN-based PID assignment, you do not need to disable the switch.
1. Connect to the switch and log in using an account assigned to the admin role.
2. Enter the configure command.
3. At the Fabric Parameters prompt, type y
4. At the WWN Based persistent PID prompt, type y
5. Press Enter to bypass the remaining prompts without changing them.
Example of activating PID assignments
Configure...
Fabric parameters (yes, y, no, n): y
WWN Based persistent PID (yes, y, no, n): y
Take a look, try it and let us know if this helped you so we can also get feedback.
Cheers!
Anonymous
I initially setup the switch before we migrated to have WWNaddress based PID assignments enabled.  It works just fine for our ESX, and AIX hosts but the tape environment did not behave well.  Our write speeds to tape were reduced by 70%.  I unbound the PID assignments for the tape drives and moved them to new ports and the speeds recovered.
