Anonymous
DCX Sensor ID 12 Temp High, is it possible to deepdive more, why this temp increasing?
it had been in 40's always, but recently a few weeks earlier its triggering 43
Can Somebody help me identify what could be the reason?
SP_DCX_BOT:prprem> sensorshow
sensor  1: (Temperature ) is Ok, value is 33 C
sensor  2: (Temperature ) is Ok, value is 35 C
sensor  3: (Temperature ) is Ok, value is 27 C
sensor  4: (Temperature ) is Ok, value is 29 C
sensor  5: (Temperature ) is Ok, value is 26 C
sensor  6: (Temperature ) is Ok, value is 35 C
sensor  7: (Temperature ) is Ok, value is 29 C
sensor  8: (Temperature ) is Absent
sensor  9: (Temperature ) is Ok, value is 30 C
sensor 10: (Temperature ) is Ok, value is 42 C
sensor 11: (Temperature ) is Ok, value is 37 C
sensor 12: (Temperature ) is Ok, value is 43 C
sensor 13: (Temperature ) is Ok, value is 28 C
sensor 14: (Temperature ) is Ok, value is 40 C
sensor 15: (Temperature ) is Ok, value is 35 C
sensor 16: (Temperature ) is Ok, value is 41 C
sensor 17: (Temperature ) is Ok, value is 33 C
sensor 18: (Temperature ) is Ok, value is 27 C
sensor 19: (Temperature ) is Ok, value is 31 C
sensor 20: (Temperature ) is Ok, value is 28 C
sensor 21: (Temperature ) is Ok, value is 33 C
sensor 22: (Temperature ) is Ok, value is 28 C
sensor 23: (Temperature ) is Ok, value is 32 C
sensor 24: (Temperature ) is Ok, value is 29 C
sensor 25: (Temperature ) is Absent
sensor 26: (Temperature ) is Ok, value is 33 C
sensor 27: (Temperature ) is Ok, value is 40 C
sensor 28: (Temperature ) is Ok, value is 29 C
sensor 29: (Temperature ) is Ok, value is 30 C
sensor 30: (Temperature ) is Ok, value is 29 C
sensor 31: (Temperature ) is Ok, value is 41 C
sensor 32: (Temperature ) is Ok, value is 31 C
sensor 33: (Fan         ) is Ok,speed is 1818 RPM
sensor 34: (Fan         ) is Ok,speed is 1818 RPM
sensor 35: (Power Supply) is Ok
sensor 36: (Power Supply) is Ok
SP_DCX_BOT:prprem> tempshow
Sensor  Slot    State             Centigrade     Fahrenheit
  ID
  1       1     Ok                  33             91
  2       1     Ok                  35             95
  3       1     Ok                  27             80
  4       1     Ok                  29             84
  5       1     Ok                  26             78
  6       1     Ok                  35             95
  7       1     Ok                  29             84
  8       2     Absent
  9       4     Ok                  30             86
 10       4     Ok                  42            107
 11       4     Ok                  37             98
 12       4     Ok                  43            109
 13       5     Ok                  28             82
 14       5     Ok                  40            104
 15       5     Ok                  35             95
 16       5     Ok                  41            105
 17       3     Ok                  33             91
 18       3     Ok                  27             80
 19       3     Ok                  31             87
 20       3     Ok                  28             82
 21       6     Ok                  33             91
 22       6     Ok                  27             80
 23       6     Ok                  32             89
 24       6     Ok                  29             84
 25       7     Absent
 26       8     Ok                  33             91
 27       8     Ok                  40            104
 28       8     Ok                  29             84
 29       8     Ok                  30             86
 30       8     Ok                  29             84
 31       8     Ok                  41            105
 32       8     Ok                  31             87
