Occasional Contributor
CRC and PCS_ERR on a DWDM connection
If I run a D_Port test the error look like this on the different sites:
Site 1:
           frames      enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy  c3timeout    pcs
        tx     rx      in    err    g_eof  shrt   long   eof     out   c3    fail    sync   sig                  tx    rx     err
 11:    1.0m   1.0m   0    793.3k   5      0      0      0      0      0      0      0      0      0      0      0      0    105.8k
Site 2:
 11:    1.0m   1.0m   0    793.3k   0      0      0      0      0      0      0      0      0      0      0      0      0      0
The 2 ports are connected with DWDM.
The main difference in the error report is the pcs_err.
I'm sure I have a SFP error, but I would like to share this error picture with you all. Because I see a different picture on a connection that are connected with DWDM.
1. I will start with changing the SFPs on the site with "PCS" errors in the brocade switch.
2. I will change the SFP in the DWDM switch.
3. If number 1 and 2 does not work I will change the cable.
If this does not work I will do the same on the other site.
I will try to keep you posted, please supply your experience...
External Moderator
Re: CRC and PCS_ERR on a DWDM connection
@JATON_1
--->>>I'm sure I have a SFP error, ....
this is possible but the reason can be another.
is this a NEW Installation or already in Productions ?
can you please post  a bit more info ?
- switch type/modell
- WDM Vendor/Modell
- FOS Release
- SFP Type, both Switch side and WDM Side
- what is the Distance beetwen both side ?
- "licenseshow" and "portcfgshow port_number" output
TechHelp24
It is running in production 2.7 years
switchType:     133.0
- WDM Vendor/Modell
Brocade
- FOS Release
Fabric OS:  v7.4.1d
Switch
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-0000089-01
DWDM
Smartoptics will change that to brocade SFPs it is supported.
Estimated cable distance:       30530 meters (30.530 Km)
licenseshow
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX:
    Extended Fabric license
    Fabric Watch license
    Performance Monitor license
    Trunking license
    Fabric Vision license
    Full Ports on Demand license - additional 48 port upgrade license
    Second Ports on Demand license - additional 24 port upgrade license
portcfgshow 11
Area Number:              11
Octet Speed Combo:        1(16G|8G|4G|2G)
Speed Level:              16G
AL_PA Offset 13:          OFF
Trunk Port                ON
Long Distance             LS
VC Link Init              ON
Desired Distance          90 Km
Reserved Buffers          726
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
Persistent Disable        OFF
LOS TOV mode              0(OFF)
NPIV capability           ON
QOS Port                  OFF
Port Auto Disable:        OFF
Rate Limit                OFF
EX Port                   OFF
Mirror Port               OFF
SIM Port                  OFF
Credit Recovery           ON
F_Port Buffers            OFF
E_Port Credits            OFF
Fault Delay:              0(R_A_TOV)
NPIV PP Limit:            126
NPIV FLOGI Logout:        OFF
CSCTL mode:               OFF
TDZ mode:                 OFF
D-Port mode:              ON
D-Port over DWDM:         ON
Compression:              OFF
Encryption:               OFF
FEC:                      ON
FEC via TTS:              OFF
8G Non-DFE:               OFF(Auto)
It is port of a 4 port trunk all the other connections are working.
External Moderator
@JATON_1
--->>>It is port of a 4 port trunk all the other connections are working.
from your first Topic was not clear that the ISL is a Trunk. Is the error occurred on the entire trunk or just only at Port 11 ?
additional I note, VC-Link Init is set on ON what is correct, however is the correct Mode set ?
did you have a Fixed buffer set on those Port ?
TechHelp24
Yes sorry :-)
And I only see errors on port 11.
Yes VC-Link is ON mode is LS (se below)
Yes
   8       E      LS       726      182(2056)     179(2028)         726     726        90km
   9       E      LS       726      181(2052)     176(1996)         726     726        90km
  10       E      LS       726      180(2040)     176(1996)         726     726        90km
  11              LS       726       - (  - )      - (  - )           0       -          -
Right now I have it in D-Port using the dwdm variable:
portcfgdport --enable -dwdm 11
But that is only for testing.
External Moderator
Jannik,
at this point - as saied probable the SFP or cable is defective -
alternative, did you try to disable the port in question and enable again ?
TechHelp24
