Anonymous
Brocade dual path, short and long on DCX 8510 backbone
Hi Guys,  I'm pretty new to the SAN fabric world, so please forgive me if I'm not clear on what I am trying to accomplish.
We have 4 DCX 8510.
2 dcx at primary site
2 dcx at secondary site
The previous SAN guy already configure the dwdm settings on the 4 of the ports, but only 2 of them are working correctly when I go plug int the fc cable.
For trouble shooting purpose, I swap out the fc cables on the ports and still only 1 path is working, the other port status shows in_sync but the health is offline and on the other end it shows no_light offline...  so I hope you guys can help me, I tried goggling it but can't find anything on it.
Anonymous
Re: Brocade dual path, short and long on DCX 8510 backbone
Don't want to be rude but if you search the way you explain I'm not surprised you didn't find anything.
I mean
-no schematics
-no info on dwdm gear used (brandactive/passive)
-no info on which to cables you swapped between what actually?
-what SFP's
-Distance
-ISL settings
Please provide a description of you issue with most detail you are allowed to do.
External Moderator
first at all, you should identify how the WDM are configures, SFP type, Speed Settings,...
if the WDM is correct configured, is probable on DCX side, you have wrong SFP or wrong Port Settings.
command sfpshow give the output SFP details, with portcfgshow you get detail son working and no-working port
Try please to collect more info and post here.
TechHelp24
Anonymous
Thanks for your help, I will run the commands and post them..
Anonymous
Here is our 2 of our DR site brocade dcx settings:
DR SITE DCX Spiel> sfpshow 11/9
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 540c404000000000 2,4,8_Gbps M5,M6 sw Short_dist
Encoding:    1    8B10B
Baud Rate:   85   (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u:  5    (units 10 meters)
Length 62.5u:2    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-1000012-01
Vendor Rev:  A
Wavelength:  850  (units nm)
Options:     003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   UAF1085200003K0
Date Code:   081221
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0xb0
Alarm flags = 0x5, 0x0
Warn Flags = 0x5, 0x0
                                          Alarm                  Warn
                                   low        high       low         high
Temperature: 47      Centigrade    -10         90         -5          85
Current:     8.562   mAmps          1.000      17.000     2.000       14.000
Voltage:     3268.3  mVolts         2900.0      3700.0    3000.0       3600.0
RX Power:    -1.7    dBm (672.3uW) 10.0   uW 1258.9 uW   15.8   uW  1000.0 uW
TX Power:    -3.3    dBm (463.5 uW)125.9  uW   631.0  uW  158.5  uW   562.3  uW
State transitions: 12
portcfgshow 11/9
Area Number:              105
Speed Level:              8G
Fill Word(On Active)      3(A-A then SW I-A)
Fill Word(Current)        3(A-A then SW I-A)
AL_PA Offset 13:          OFF
Trunk Port                OFF
Long Distance             LS
VC Link Init              ON
Desired Distance          250 Km
Reserved Buffers          1006
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            ON
RSCN Suppressed           OFF
Persistent Disable        OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                OFF
Port Auto Disable:        OFF
Rate Limit                OFF
EX Port                   ON
Mirror Port               OFF
Credit Recovery           OFF
F_Port Buffers            OFF
Fault Delay:              0(R_A_TOV)
NPIV PP Limit:            126
CSCTL mode:               OFF
****** NOT WORKING *****
sfpshow 11/33
Identifier:  3    SFP
Connector:   7    LC
Encoding:    1    8B10B
Vendor Rev:  A
BR Max:      0
BR Min:      0
Serial No:   UAF108520000KBL
Date Code:   081226
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0xb0
                                          Alarm                  Warn
                                   low        high       low         high
Temperature: 46      Centigrade    -10         90         -5          85
Current:     7.466   mAmps          1.000      17.000     2.000       14.000
Voltage:     3268.6  mVolts         2900.0      3700.0    3000.0       3600.0
RX Power:    -2.2    dBm (596.1uW) 10.0   uW 1258.9 uW   15.8   uW  1000.0 uW
TX Power:    -3.2    dBm (479.2 uW)125.9  uW   631.0  uW  158.5  uW   562.3  uW
portcfgshow 11/33
Area Number:              233
Speed Level:              8G
Trunk Port                OFF
Long Distance             LS
VC Link Init              ON
Desired Distance          200 Km
Reserved Buffers          806
Locked L_Port             OFF
Locked G_Port             OFF
Disabled E_Port           OFF
Locked E_Port             OFF
ISL R_RDY Mode            ON
RSCN Suppressed           OFF
LOS TOV enable            OFF
NPIV capability           ON
QOS E_Port                OFF
Rate Limit                OFF
EX Port                   ON
Mirror Port               OFF
Credit Recovery           OFF
F_Port Buffers            OFF
NPIV PP Limit:            126
CSCTL mode:               OFF
Anonymous
Would you like me to post the same info for the other dcx at our primary site?
Anonymous
Hi,
any idea on the WDM type, module types ? A picture perhaps?
Uli
