Anonymous
Re: Brocade Silkworm 2400 connection to JBOD
Hi
I tried the above commands, but still no luck
BROCADE:admin> portshow 2
portFlags: 0xc0020041    PRESENT U_PORT LED CFG_L_PORT DISABLE_EPORT
portType:  3.1
portState: 2    Offline
portPhys:  6    In_Sync
portScn:   0
portRegs:  0x80010000
portData:  0x102f8290
portId:    011200
portWwn:   20:02:00:60:69:20:1f:59
portWwn of the device(s) connected:
        None
Distance:  normal
Speed:     1Gbps
Interrupts:   3856       Link_failure: 0          Frjt:         0
Unknown:      2157       Loss_of_sync: 38         Fbsy:         0
Lli:          3001       Loss_of_sig:  7
Proc_rqrd:    3          Protocol_err: 0
Timed_out:    0          Invalid_word: 156
Rx_flushed:   0          Invalid_crc:  14
Tx_unavail:   0          Delim_err:    0
Free_buffer:  0          Address_err:  3
Overrun:      0          Lr_in:        0
Suspended:    0          Lr_out:       0
Parity_err:   0          Ols_in:       0
                         Ols_out:      1673
BROCADE:admin>
Also,
BROCADE:admin> nsshow
Type Pid    COS     PortName                NodeName                 TTL(sec)
N    011000;      3;21:02:00:e0:8b:4e:bc:b3;20:02:00:e0:8b:4e:bc:b3; na
    FC4s: FCP
    NodeSymb: "QLA2344 FW:v3.03.25 DVR:v9.1.7.18"
    Fabric Port Name: 20:00:00:60:69:20:1f:59
The Local Name Server has 1 entry }
BROCADE:admin>
Any other idea??
Valued Contributor
Hi,
Command portcfglport has the following parameters:
Usage: portCfgLport PortNumber  <0 | 1>
You could try to configure all the different possibilities to see if any of them makes the device to get online. Try, on port 2, to configure a Public Loop instead of  a private one, for example.
BROCADE:admin>portcfglport 2 1 1 <-- private Loop
BROCADE:admin>portcfglport 2 1 0 <-- public Loop
rgds
