Anonymous
Brocade Silkworm 2400 connection to JBOD
Hi
I am new to brocade, any idea how to configure brocade 2400 silkworm in FabricLoop mode. i.e. I have Netapp 2Gig Disk shelf with 6 disks. Brocade port0 is connected to Server HBA and it comes as F port but i cannot bring up Jbod link. Any idea which command is need to bring up the FL link.
Thanks
Muhammad
External Moderator
Re: Brocade Silkworm 2400 connection to JBOD
WOW, 10 Years nostalgic.
Honestly, as fair as i remember - is long time ago -  LOOP was in FOS 2.6 - a Additional License.
Secong 2400 is 1Gb switch, if the JBOD work with fixed 2Gb, and cannot auto-negotiated to 1Gb you cannot connect to.
TechHelp24
Anonymous
Right,
It is bit old but good enough to do interop mode with Cisco MDS 9222i. You are right, I have switched JBOD to 1Gig speed, so are my HBA. HBA works fine but have issue with Loop.
Here is output from Brocade:
BROCADE:admin> fabricshow
Switch ID   Worldwide Name           Enet IP Addr    FC IP Addr      Name
  1: fffc01 10:00:00:60:69:20:1f:59  172.16.3.221    0.0.0.0        >"BROCADE"
  2: fffc02 20:32:00:0d:ec:0f:d5:01  172.16.3.151    0.0.0.0         "MDS1"
The Fabric has 2 switches
Any thoughts??
External Moderator
post the licenseshow from brocade please
TechHelp24
Anonymous
Here is license report:
BROCADE:admin> licenseshow
cSbeddzSdddTcfeH:
    Fabric license
cbSeRedbQdcTfSr:
    Web license
    Zoning license
    SES license
Rdybecy9cSSezcfQ:
    QuickLoop license
bQz99zebQzfR0MBY:
    Web license
    Zoning license
    SES license
    QuickLoop license
    Fabric license
    Remote Switch license
    Remote Fabric license
    Extended Fabric license
    Entry Fabric license
    Fabric Watch license
    Release v2.2 license
BROCADE:admin>
External Moderator
from license output show ok, check in command reference 2.6 if you find one, is probable you have to made some settings in  the switch.
I don't at the moment thin on the hand, i believe in command "configure" you should be able to set LOOP Features.
TechHelp24
Anonymous
Here is the output from Port where JBOD is connected:
BROCADE:admin> portshow 2
portFlags: 0xc0020041    PRESENT U_PORT LED CFG_L_PORT DISABLE_EPORT
portType:  3.1
portState: 2    Offline
portPhys:  6    In_Sync
portScn:   0
portRegs:  0x80010000
portData:  0x102f8290
portId:    011200
portWwn:   20:02:00:60:69:20:1f:59
portWwn of the device(s) connected:
        None
Distance:  normal
Speed:     1Gbps
Interrupts:   72         Link_failure: 0          Frjt:         0
Unknown:      76         Loss_of_sync: 2          Fbsy:         0
Lli:          34         Loss_of_sig:  2
Proc_rqrd:    0          Protocol_err: 0
Timed_out:    0          Invalid_word: 0
Rx_flushed:   0          Invalid_crc:  0
Tx_unavail:   0          Delim_err:    0
Free_buffer:  0          Address_err:  0
Overrun:      0          Lr_in:        0
Suspended:    0          Lr_out:       0
Parity_err:   0          Ols_in:       0
                         Ols_out:      0
BROCADE:admin>
I see solid orange light on the port.
External Moderator
command "portcfglport port_number 1" must be set to enable L_Port
TechHelp24
Anonymous
I tired this command,
ROCADE:admin> portcfglport
Ports:   0   1   2   3   4   5   6   7
Lock     -   -   YES -   -   -   -   -
Private  -   YES YES -   -   -   -   -
BROCADE:admin>
As you can see it is setup for lport but still i dont see the drives.
External Moderator
try again with follow step.
disconnect the cable from that port you want to configure
command "portdisable Port_number"
command "portcfglport Port_number 1" Note 1 is the operand to set L_Port enable
enable the port back with command "portenable Port_number"
plug the cable and wait for a couple of second.
verify with command "nsshow" you should see all attached device.
TechHelp24
