Anonymous
Brocade FC switches
Hi
We have Hitachi AMS-2100 and HUS-110 FC Storages. We want to procure Brocade FC switch. Will anyone please suggest me compatible FC switches?
Thanks
Bhanu
Anonymous
Re: Brocade FC switches
We are using the 6510's at our location to connect our Hitachi CB500's
Jonathan,
Valued Contributor
hitachi storage complies with all the FC standards and specs *proud_smiley*
so any modern 8G/16G switch will work for you
Anonymous
Thanks for reply.
Will you please suggest me some brocade models?
Thanks
Bhanu
Valued Contributor
this depends on the number of ports you expect to have in your SAN. i think 6505 or 6510 will be good for you, but please note that it's best to have dual redundant SAN, which means that you'll need a pair of devices.
Anonymous
Hi,
I do not have production environment. We have to use this switch for storage testing project. I want 48 ports FC switch.
Shall I distinguish this one switch in two, so that I can connect two different storages to one switch?
Thanks
Bhanu
Anonymous
48 ports >>> buy a 6510
^^^that's per your own requirements, compatibility, budget, need to haves, nice to haves etcetc.
In essence you can connect as many storage to 1 switch as you have ports available.
Anonymous
Thanks for the reply.
Shall I used following Brocade switches for AMS 2100 and HUS 110 storage
  1. BR-5100 – 8G - 40port switch fully populated
  2. BR-5100 – 8G - 24port active.
  3. Brocade DS-4900 – 4G - 32port active
Thanks
Bhanu
