Anonymous
Brocade 4900 and HP2 8GB SAN Switches
Hi everyone.  I'm brand new to fiber channel switches.  I'm trying to connect an 8GB blade chassis san switch to my existing brocade 4GB 4900 fabric.  It's giving me nothing but errors.  No matter if I change cables, ports, modules, etc it always settles into this pattern:
Brocade side:
RX Power:    -40.0  dBm (0.1 uWatts)
TX Power:    -4.6  dBm (349.8 uWatts)
Chassis side:
                                          Alarm                  Warn
                                      low        high       low         high
Temperature: 31      Centigrade     -15         100        -10         95
Current:     0.002   mAmps          2.000       8.500      2.000       8.500
Voltage:     3273.0  mVolts         2800.0      3800.0     2970.0      3630.0
RX Power:    -5.0    dBm (316.8 uW) 0.0    uW   6550.0 uW  49.0   uW   1100.0 uW
TX Power:    -40.0   dBm (0.1   uW) 50.0   uW   800.0  uW  100.0  uW   700.0  uW
The chassis switch is fab os version: 6.3.2e and the brocade 4900 is 6.2.2f.  Are these two products compatible?
Brocade side:
fc64sw101d:root> portcfgshow 14
Area Number:  14
Speed Level:  4G
Fill Word:  0(Idle-Idle)
AL_PA Offset 13:  OFF
Trunk Port  ON
Long Distance  OFF
VC Link Init  OFF
Locked L_Port  OFF
Locked G_Port  OFF
Disabled E_Port  OFF
ISL R_RDY Mode  OFF
RSCN Suppressed  OFF
Persistent Disable  OFF
NPIV capability  ON
QOS E_Port  OFF
Port Auto Disable:  OFF
Mirror Port  OFF
F_Port Buffers  OFF
Chassis side:
fcbsw112d:root> portcfgshow 20
Area Number:  20
Speed Level:  4G
Trunk Port  ON
Long Distance  OFF
VC Link Init  OFF
Locked L_Port  OFF
Locked G_Port  OFF
Disabled E_Port  OFF
ISL R_RDY Mode  OFF
RSCN Suppressed  OFF
NPIV capability  ON
QOS E_Port  OFF
Rate Limit  OFF
Mirror Port  OFF
Credit Recovery  OFF
F_Port Buffers  OFF
Fault Delay:  0(R_A_TOV)
Any help would be really appreciated.  I'm stuck as to why these are not talking to one another.  HP support said their chassis switch was completely fine.
External Moderator
Re: Brocade 4900 and HP2 8GB SAN Switches
Hello,
--->>> I'm trying to connect an 8GB blade chassis san switch to my existing brocade 4GB 4900 fabric.
check please Both ( Blade and 4900) Domain ID, keepin mind each switch in the Fabric must have unique Domain ID,
switchshow command output can you see the current domain ID in both switch.
From you post, show as the 4900 is productive, in such case if both have same DID you shold change DID in new non-productive switch.
Another problem, make sure both have compatible FOS release.
TechHelp24
Anonymous
switchshow says the domain id's are unique, so that's good.  How would I check to see if the FOS releases are compatible?  I originally had both on 6.2.2f but that didn't work so I tried upgrading the 8Gb chassis switch to 6.3.2e.  No luck there either.
Anonymous
Hi,
to check if releases are compatible you need to read the release notes (so check the one from 6.3.2e if it says that it's compatible with 6.2.2f).
Also portdisable;portenable on the ISL port can often help.
Anonymous
TX Power:-40.0
This SFP is nearly not transmitting enough.
