Anonymous
Brocade 4424 Setup in Dell Blade Chassis
I'm setting up a new blade chassis which has two Brocade 4424's. I've configure the IP Address in both of them and am only able to ping one of them. I've tried switching locations in the chassis and removing the one that is able to ping to see if the other would would then respond. Any help or idea's?? Thanks!
Anonymous
Re: Brocade 4424 Setup in Dell Blade Chassis
You need to telnet into the switch and disable it:
switchdisable
then run the configure command to disable the EZSwitchSetup.
webtools attributes (yes, y, no, n): y
Anonymous
Thanks for your response. I followed your steps and am still not able to ping the switch or get in through the web interface. Not sure what else I can check? Anymore ideas
Anonymous
Seeing that you are not able to ping I would check with your network people and check to see if they are blocking ICMP traffic and other traffic that may not allow you to manage the switch.
