Anonymous
Brocade 300 Switches
Can the Brocade 300 switches have static routes or do they only have a default route?  Thank you.
Anonymous
Re: Brocade 300 Switches
try login as root and type the route command as seen in a linux operating system. It might work. Try the route -n first. I dont have a switch at my disposal to check.
Via the normal command interface adding the gw is the only option I have seen.
