Occasional Contributor
Brocade 200E Silkworm Switch, locked out of ssh/http and serial not working, help?
Hello,
We have older IBM branded Brocade 200E "Silkworm" switches, recently I updated them to v6.2.2g and everything working fine.
I decided to lock down the switch by disabling TELNET and I managed to lock myself out of SSH/TELNET/HTTPS so I have no way to get back onto the switch.
Then I tried the serial port (straight through DB9 cable) with 9600,8,n,1 no flow control settings; no luck getting a prompt, tried rebooting the switch, etc.
I can ping the switch fine and I stuff works, I just can't administer it.
These are older switches and we dont' keep an active maintenance on them so I am out of luck trying to get support on this.
Anyone out here have any suggestions as to what I could do next? If needs be we can factory reset it but I don't think these switches you can do this without some terminal access first? Any help would be great.
Thanks!!
External Moderator
Re: Brocade 200E Silkworm Switch, locked out of ssh/http and serial not working, help?
try with
user@switchname
example
admin@10.77.77.77
TechHelp24
[ Edited ]
The problem is SSH is disabled so I can't connect to it, SSH/TELNET/HTTP is blocked (because I created a bad ACL rule which locked me out) and I can't seem to get a serial connection to work to try and reverse the setting, the console cable (DB9 straight through cable) from brocade to laptop but I don't see anything..
Is there anything else I can do to trigger a factory reset of some sort?
External Moderator
sorry, I understand you have disable telnet and enable SSH.
you should be able to connect truogh te serial port, and enable telnet back.
did you try it ?
TechHelp24
[ Edited ]
Yes I tried serial connection but I cannot see anything, seems that serial does not work.
Does the Brocade have a special type of serial cable I need to use or can I use any straight through serial cable? I am using a DB9 female to DB9 female straight through serial cable to connect my laptop to the switch but I do not get anything on the screen it is blank.
I know the switch is up and running and I can ping it; just can't access it via serial... I tried rebooting the switch while being plugged into it via serial but nothing on the screen.
The cable I am using is identical to this..
http://www.amazon.com/Female-Serial-Straight-Thru-Cable/dp/B004ISAEAQ
What can I do?
External Moderator
-->>...seems that serial does not work.
didi you set the right parameters ?
  • Baud: 9600 bps
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow control: None
and yes brocade used proprietary cable.
TechHelp24
Yes I set the settings as stated. I do not have the proprietary cable, do you know if we can buy this somewhere? Is there a model # of the serial cable we need?
The serial cable I am using is not the original, so this could be the issue.. we don't have the original cable that shipped with it.
Frequent Contributor
[ Edited ]
Hmm... the cable is nothing magical... even Brocade says you can build your own :-)
http://community.brocade.com/t5/Design-Build/How-To-Connect-a-Console-Cable-to-Brocade-Hardware/ta-p/37039
http://community.brocade.com/dtscp75322/attachments/dtscp75322/fibre/3280/1/BRCD+48000+serial+cable+pin+out.pdf
How do you connect it to your computer? I know that some of our technicians had problems with some kinds of USB-Serial-Adapters. Does your combination of cable + USB-Serial-Adapter + terminal program work with your other Brocade switches? Or do you even still have an old PC with a com-port somewhere in the "archive" (the eternal junk room of "just in case we ever need that again")
Valued Contributor
Try using an additional null-modem converter together with the cable you have.
Regular Contributor
Indeed, null-modem cable should work. I had one which also converted to my USB port. Very handy.
Kind regards,
Erwin van Londen
Brocade Distinguished Architect
http://www.erwinvanlonden.net The Fibre Channel blog
Q&A -> https://hackhands.com/elo/
