Anonymous
After FOS Upgrade to 6.4.2a receive following errors:
Reported Errors: FSS-1009 fcsw0-swc:sync-failure:-6
Have checked the HA and there are in Sync noticed same or similar errors in earlier Release Notes, need some info how to solve or is there are a workaround for this problem.
Anonymous
Re: After FOS Upgrade to 6.4.2a receive following errors:
The FOS messages reference guide only states you should contact vendor support.
No other description or hint is given, sorry about that.
Anonymous
Hi,
did you open a call? Did you get any feedback from Brocade or your support vendor?
I have the same error code during the update from v6.4.1b to v6.4.2b on 48000 SAN directors.
Andreas
Anonymous
Perhaps you can get it in sync again (if it isn't) with hasyncstop hassyncstart
Anonymous
It get in sync without any manual help.
The question is more about what is the reason and why did it happens.
Why came this message on only one of many directors of the same fabric.
Andreas
