Turn on suggestions
Showing results for
10-04-2004 06:37 AM
I have a SAN which is connected between two sites using the 12000 switches and at either site I have disk and tape. We want to configure seperate trunks for tape and disk replication traffic, however our backup servers need to see the tape drives in both locations. Originally we wanted to use static routes to that the tape traffic was confined to one of the 2 trunks, however because the HBA's in each server is zoned to tape drives in each location I'm assumning that I cannot use static routing as backup data for the local tape drives will be routed to the other site...... Any comments?
