External Moderator
Re: 5.3.1 FOS for switch modules 3014 and 4016
another question, what is the current loaded FabOS Release ?
TechHelp24
Anonymous
OK, looks like it's working now.
The confusion is that the documentation says you only need to put in the parent directory, but it does say that it uses the release.plist file. So when I was trying to just use the parent directory without release.plist, it said it couldn't find it. So then I went looking for it and it only shows up in those subdirectories and was thinking I had to specify one of those.
So /v5.3.1/release.plist works.
Thanks for the help.
External Moderator
the DOC is correct.
--->>>... you only need to put in the parent directory,....
.....if the parent directory is in the correct FTP Folder. And each user millions of this Wolrd have another FTP configuration mode, so that Brocade cannot explained in the DOC a million of FTP configuration from each user another....
very simple.
TechHelp24
External Moderator
--->>> Thanks for the help.
would be appreciate you reate this trhreads.
TechHelp24
TechHelp24
