Anonymous
3900 losing network admin port after upgrade
Hello,
I upgraded my spare 3900 to 5.3.0d and all was well.  I was able to connect to the GUI, etc.  A few hours later I tried again and my browser window froze during the GUI load.  At that point I was unable to ping the unit.  I used serial terminal to issue a reboot.  This reset the network connection, but everytime I try to access the GUI now it locks up the network port before loading.  I have tried using different PC's to access the GUI, but get the same behavior on the 3900 (losing the network connection).  Any ideas?  Thank you.
External Moderator
Re: 3900 losing network admin port after upgrade
--->>> I upgraded my spare 3900 to 5.3.0d ....
from which release have start the upgrade to 5.3.0d ?
are you able to login in the switch trough a Console ?
TechHelp24
Anonymous
Yes, I can login from the console or via a ssh session and issue commands there no problem.  Only when I attempt to use the GUI does the network connection hang.  I upgraded from 4.4.0 to 5.0.5c to 5.2.1b to 5.3.0d, one after another before stopping to test out the results.
External Moderator
collect with the command below follow output and post here please.
switchshow
ipaddrshow
firmwareshow
errshow
TechHelp24
Anonymous
It means you are ok with your CLI. If you ar eok with your CLI, then you have check the java version for webtools GUI.Are you a UNIX expert, then CLI is too goo dman. go for CLI.
Anonymous
Before posting here, I had attempted to re-apply the firmware in hopes that might clear up the issue (as show in the log).
waterpik2:admin> switchshow
switchName:     waterpik2
switchType:     12.4
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   1
switchId:       fffc01
switchWwn:      10:00:00:60:69:90:8a:73
zoning:         OFF
switchBeacon:   OFF
Area Port Media Speed State     Proto
  0   0   id    N2   No_Light
  1   1   id    N2   No_Light
  2   2   id    N2   No_Light
  3   3   id    N2   No_Light
  4   4   id    N2   No_Light
  5   5   id    N2   No_Light
  6   6   id    N2   No_Light
  7   7   id    N2   No_Light
  8   8   id    N2   No_Light
  9   9   id    N2   No_Light
10  10   id    N2   No_Light
11  11   id    N2   No_Light
12  12   id    N2   No_Light
13  13   id    N2   No_Light
14  14   id    N2   No_Light
15  15   id    N2   No_Light
16  16   id    N2   No_Light
17  17   id    N2   No_Light
18  18   id    N2   No_Light
19  19   id    N2   No_Light
20  20   id    N2   No_Light
21  21   id    N2   No_Light
22  22   id    N2   No_Light
23  23   id    N2   No_Light
24  24   id    N2   No_Light
25  25   id    N2   No_Light
26  26   id    N2   No_Light
27  27   id    N2   No_Light
28  28   id    N2   No_Light
29  29   id    N2   No_Light
30  30   id    N2   No_Light
31  31   id    N2   No_Light
waterpik2:admin> ipaddrshow
SWITCH
Ethernet IP Address: 172.16.5.52
Ethernet Subnetmask: 255.255.0.0
Fibre Channel IP Address: none
Fibre Channel Subnetmask: none
Gateway IP Address: 172.16.8.100
DHCP: Off
waterpik2:admin> firmwareshow
Appl     Primary/Secondary Versions
FOS      v5.3.0d
         v5.3.0d
2009/02/16-16:37:19, , 117,, INFO, X00LIBC089, The effective configuration has changed
2009/02/16-16:37:39, , 118,, INFO, X00LIBC089, cfgSave completes successfully.
2009/02/16-16:53:11, , 119,, INFO, X00LIBC089, Security violation: Login failure attempt via TELNET/SSH/RSH. IP Addr: 10.35.85.149
2009/02/16-16:55:22, , 120,, INFO, gabbar7, HTTP server will be restarted due to change of IP Address
2009/05/11-14:12:57, , 121,, INFO, FB060010638, Switch reboot, reason: Unknown
2010/04/16-13:56:59, , 122,, INFO, FB060010638, Switch reboot, reason: Unknown
2010/04/16-16:05:12, , 123,, INFO, gabbar7, Security violation: Login failure attempt via SERIAL.
2010/04/16-16:11:25, , 124,, INFO, gabbar7, HTTP server will be restarted due to change of IP Address
2010/04/16-16:59:13, , 125,, WARNING, gabbar7, Switch status changed from HEALTHY to MARGINAL.
2010/04/16-16:59:13, , 126,, WARNING, gabbar7, Switch status change contributing factor Switch offline.
2010/04/16-17:00:17, , 127,, INFO, gabbar7, Switch status changed from MARGINAL to HEALTHY.
2010/04/16-17:38:41, , 128,, WARNING, FB060010638, Firmwaredownload command has started.
2010/04/16-17:38:45, , 129,, INFO, FB060010638, Firmwaredownload command failed (0x4412).
2010/04/16-17:39:39, , 130,, WARNING, FB060010638, Firmwaredownload command has started.
2010/04/16-17:39:43, , 131,, INFO, FB060010638, Firmwaredownload command failed (0x4412).
2010/04/16-17:44:37, , 132,, WARNING, FB060010638, Firmwaredownload command has started.
2010/04/16-17:49:12, , 133,, INFO, FB060010638, Firmwaredownload command has completed successfully.
2010/04/16-17:49:19, , 134,, INFO, FB060010638, HA State is in sync
2010/04/16-17:49:19, , 135,, WARNING, FB060010638, HA State out of sync
2010/04/16-17:49:59, , 136,, INFO, FB060010638, Processor rebooted - Unknown
2010/04/16-17:50:16, , 137,, INFO, FB060010638, HA State is in sync
2010/04/16-17:50:16, , 138,, WARNING, FB060010638, HA State out of sync
2010/04/16-17:53:47, , 139,, INFO, FB060010638, The new Version: Fabric OS v5.0.5c
2010/04/16-17:53:47, , 140,, INFO, FB060010638, Firmwaredownload command has completed successfully.
2010/04/16-17:55:38, , 141,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: wp12770.fc.waterpik.pik
2010/04/16-17:58:16, , 142,, WARNING, FB060010638, Firmwaredownload command has started.
2010/04/16-17:58:16, , 143,, INFO, FB060010638, The current Version: Fabric OS v5.0.5c
2010/04/16-18:04:09, , 144,, INFO, FB060010638, Firmwaredownload command has completed successfully.
2010/04/16-18:05:01, , 145,, INFO, FB060010638, Processor rebooted - FirmwareDownload
2010/04/16-18:05:29, , 146,, INFO, FB060010638, HA State is in sync
2010/04/16-18:05:29, , 147,, WARNING, FB060010638, HA State out of sync
2010/04/16-18:08:42, , 148,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: 172.16.70.19
2010/04/16-18:09:36, , 149,, INFO, FB060010638, The new Version: Fabric OS v5.2.1b
2010/04/16-18:10:56, , 150,, INFO, FB060010638, The current Version: Fabric OS v5.2.1b
2010/04/16-18:17:31, , 151,, INFO, FB060010638, HA State is in sync
2010/04/16-18:17:31, , 152,, WARNING, FB060010638, HA State out of sync
2010/04/16-18:18:16, , 154,, INFO, FB060010638, Processor rebooted - FirmwareDownload
2010/04/16-18:18:36, , 154,, INFO, FB060010638, HA State is in sync.
2010/04/16-18:18:36, , 155,, WARNING, FB060010638, HA State out of sync.
2010/04/16-18:18:58, , 156,, INFO, FB060010638, Firmwarecommit has started.
2010/04/16-18:19:02, , 157,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: wp12770.fc.waterpik.pik
2010/04/16-18:22:32, , 158,, INFO, FB060010638, The new Version: Fabric OS v5.3.0d
2010/04/16-18:22:32, , 159,, INFO, FB060010638, Firmwaredownload command has completed successfully.
2010/04/16-18:26:40, , 160,, INFO, FB060010638, Processor rebooted - Reboot
2010/04/16-18:28:12, , 161,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: dpc-xp-1.fc.waterpik.pik
2010/04/16-19:06:59, , 162,, WARNING, waterpik2, Env Power Supply 2, is below low boundary(High=0, Low=1). Current value is 0 (1 OK/0 FAULTY).
2010/04/16-19:06:59, , 163,, WARNING, waterpik2, Switch status changed from HEALTHY to MARGINAL.
2010/04/16-19:06:59, , 164,, WARNING, waterpik2, Switch status change contributing factor Power supply: 1 bad.
2010/04/16-19:06:59, , 165,, ERROR, FB060010638, PS 2 set to faulty, rc=2000e.
2010/04/16-19:08:45, , 166,, INFO, FB060010638, Processor rebooted - Unknown
2010/04/16-21:28:36, , 167,, INFO, FB060010638, Processor rebooted - Reboot
2010/04/16-21:31:35, , 168,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: dpc-xp-1.fc.waterpik.pik
2010/04/16-21:33:23, , 169,, WARNING, FB060010638, Firmwaredownload command has started.
2010/04/16-21:33:23, , 170,, INFO, FB060010638, The current Version: Fabric OS v5.3.0d
2010/04/16-21:37:04, , 171,, INFO, FB060010638, Firmwaredownload command failed. status: 0x44, error: 0x15.
2010/04/16-21:37:09, , 172,, INFO, FB060010638, Firmwarecommit has started.
2010/04/16-21:42:20, , 173,, INFO, FB060010638, Processor rebooted - Reboot
2010/04/16-21:46:10, , 174,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: 172.16.70.19
2010/04/16-21:56:45, , 175,, INFO, FB060010638, Processor rebooted - Reboot
2010/04/16-22:02:56, , 176,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: 172.16.70.60
2010/04/16-22:09:28, , 177,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: wp12770.fc.waterpik.pik
2010/04/16-22:21:09, , 178,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: 172.16.70.19
2010/04/16-22:22:27, , 179,, WARNING, waterpik2, Switch status changed from HEALTHY to MARGINAL.
2010/04/16-22:23:06, , 180,, INFO, waterpik2, Switch status changed from MARGINAL to HEALTHY.
2010/04/16-22:23:19, , 181,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: wp12848.fc.waterpik.pik
2010/04/16-22:39:29, , 182,, WARNING, waterpik2, Switch status changed from HEALTHY to MARGINAL.
2010/04/16-22:48:13, , 183,, WARNING, FB060010638, Firmwaredownload command has started.
2010/04/16-22:48:13, , 184,, INFO, FB060010638, The current Version: Fabric OS v5.3.0d
2010/04/16-22:52:26, , 185,, INFO, FB060010638, Firmwaredownload command failed. status: 0x44, error: 0x15.
2010/04/16-22:52:32, , 186,, INFO, FB060010638, Firmwarecommit has started.
2010/04/17-14:43:48, , 187,, INFO, FB060010638, Processor rebooted - Reboot
2010/04/17-14:44:10, , 188,, WARNING, waterpik2, Zoning file doesn't exist or Corrupted Zoning files detected before reboot, currently the file is saved at /etc/fabos/zone.0.conf.
2010/04/17-15:21:37, , 189,, INFO, waterpik2, Login information: Login successful via TELNET/SSH/RSH. IP Addr: 172.16.70.18
External Moderator
the output see ok.
that show to me the problem is caused by the LAN.
Check please follow, in IE, start ->Tools-> Internet Option -> in LAN Settings uncheck all check Box.
If you use a Firewall making sure the Switch IP is not  behind the FW
set temporarely of Disable a FW in you PC, test now.
let me know
TechHelp24
Anonymous
Yea.. agreed with hemant. I have encounter the similar problem before.. and after upgrade the Java version then it works fine. You may check your Java version if it required higher version to support.
Anonymous
I would try to go to Control Panel -> Java -> Temporary Internet Files (Settings...) -> Delete Files...
That would clear the Java cache for the applets.
Hope it helps =)
Anonymous
My internet connection / proxy boxes are all clear.  I tried clearing the Jave temp cache.  No change in the behavior.  I lose the network connection (including pinging) whenever I try to invoke the GUI.  I'm not sure if I understand the comments on upgrade the Java version - is this on the brocade or on my PC?  Thanks for all of your suggestions so far.
Additionally - my other 3900; which I also upgraded using the same process and files has no issues using the same PC to access the GUI, etc.
