Info & Feedback
New Member
crt5a2 system error lsi not detected
Hello,
My system is not detected anymore the raid controller.
The red led is blinking on the card (CRT5a2 Led)
I changed the PCI card location and i did a reset to bios but nothing happened
Super Contributor
Re: crt5a2 system error lsi not detected
Hello,
i guess that you are on wrong forum.
Please mark this response as "Accept as Solution" if it answers your question.
Marian Bezeg
Frequent Contributor
CRT5a2 is related to LSI 3ware product.   This is a forum for Brocade SAN fibre channel products and solutions.
I think your question has been posted to the wrong forum.
The comments and advise included are the author's and do not mirror the views and opinions of any company. Any comments, advise, statements or references are without warranty, liability or claims of expertise. You should seek the assistance of the professional entity for subject matter being pursued.
External Moderator
@stevendahdah
@Marian Bezeg
@dtocci
following the correct answer.
LSI bought years ago 3Ware. later If I rememebr correct 2014 ? LSI was acquired by AKA AVAGO today Broadcom Inc.
anyway, this Controller is around 10 Years old, and not longer supported neither by AVAGO nor any other Vendor.
TechHelp24
Regular Contributor
Typically, a red LED blinking indicates a device failure.
I would recommend reviewing POST startup to see what messages are displayed. Most likely, you will need to replace this card.
