Fibre Channel (SAN) Technical Documents
sancfgmaker
by Anonymous ‎09-22-2005 04:00 PM - edited ‎10-30-2013 01:35 PM (442 Views)
DETAILED DESCRIPTION
This script was designed to generate the mrtg config entries for brocade san ports. (running MRTG's cfgmaker only generates the config for ethernet ports).
The script requires perl and mrtg.
REQUIREMENTS
Operating System Unix
Interface Any
Fabric Operating System Any version
Other tested with brocade silkworm 4100 32 ports, and brocade 16 ports
NOTES (INCLUDING LIMITATIONS)
you still have to generate the config for ethernet ports using cfgmaker.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
