Fibre Channel (SAN) Technical Documents
Brocade 24k MRTG cfgMaker
by Anonymous ‎09-21-2005 04:00 PM - edited ‎10-30-2013 01:35 PM (779 Views)
DETAILED DESCRIPTION  <br/>
<br/>
This is a cfgMaker for MRTG that is built from the ground up to build configs for Brocade Switches. It was built for 24k switches but should work with other 2GB switches, and possibly 1GB if modified. The config file that is output will build based on the ports, whether up or down, to collect Rx/Tx stats, Readys Exceeded vs No Transmit Credits and Encoding Error/Disparity Error Inside vs Outside Frames. Credit is given when/where it is due. <br/>
<p/>
REQUIREMENTS  <br/>
<br/>
Operating System  Windows Xp Pro, but truely with some edits any perl-enabled OS should work with minor mods
Interface MRTG, which has a commandline and HTML files
Fabric Operating System v4.2.0b, but should work with all v4.x
Other Give me Feed Back or Change Requests....
NOTES (INCLUDING LIMITATIONS)
You Will need to have perl (using v5.8.7) and MRTG (2.12.2) up and running. Make any changes to Global Options based on your config:
LoadMIBs: C:
mrtg
mibs
v3_0.mib
HtmlDir: C:
inetpub
wwwroot
Mrtg_San
$sysName
ImageDir: C:
inetpub
wwwroot
Mrtg_San
$sysName
images
LogDir: C:
inetpub
wwwroot
Mrtg_San
$sysName
log
  • Make sure you leave $sysname if you want switch-specific dirs
{to Append to a Config}
Brocade_24k_cfgMaker.pl \@ >>mrtg.cfg {to overwrite/create a config}
Brocade_24k_cfgMaker.pl \@ >mrtg.cfg
Then run mrtg with the specific config file.
NOTE: This contribution was migrated by Brocade from the former Brocade Connect community on March 13, 2008, on behalf of the author.
Contributors
