Anonymous
password reset problem
Hello All,
today I tried to reset my password in mcdata4400 and it's failed.
connected the switch thru serial and made the term config as
o      115200 baud
o      8-bit
o      No parity
o      1 stop bit
got the prompt as > then entered the password as 'neergcm' got the SSP> prompt.it never asked for the login.when i did the cmd 'pswd_reset'
got the o/p as INVALID COMMAND.
can any one help me to reset the password?
thanks,
raju
External Moderator
Re: password reset problem
here is the Reset procedure.
Follow this Threads. Note, after reset all :License wil lbe lost as descripted in the Threads below.
http://community.brocade.com/home/message/7775#7775
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thanks!
TechHelp24
Anonymous
thank u for the response,
I don't want to loose all my license.the ver is
P} SSP>ver
Version:   08.00.012
Build ID:         2
{P} SSP>
is there any way? it's connected to a production system.
thanks,
raju
External Moderator
--->>> I don't want to loose all my license.
And i don't have another procedure.
Sorry
If you have a Active Mantenance Contract open a Call by Brocade.
TechHelp24
Anonymous
like to know the pswd_reset command is not valid for
Version:   08.00.012?
if so the only solution is to involve the support team...
External Moderator
Raju,
i help here a lot of People with similary problem.
Sincerely, if i would have another procedure... i would say.
sorry for that.
TechHelp24
