Anonymous
nport zoning using CLI
Hello all,
I am interested in zoning an n-port using the CLI.  Would I use the alicreate as I would do normally if I were zoning an physical HBA?  What is the command that would display the PWWNs served up via. NPIV?
I found several articles that detail the GUI procedure creating an alias as an "other" port, but none for the CLI.  Any suggestions would be greatly appreciated.
Regards,
WS
Valued Contributor
Re: nport zoning using CLI
switchshow:
Index Slot Port Address Media Speed State Proto
48 4 0 0c3000 id N8 Online FC F-Port 1 N Port + 4 NPIV public
portshow 48:
portWwn of device(s) connected:
10:00:00:00:c9:cb:21:8a
10:00:00:00:c9:cb:5d:78
10:00:00:00:c9:cb:65:74
10:00:00:00:c9:cb:60:e8
20:11:00:05:33:da:02:81
portloginshow 48:
Type PID World Wide Name credit df_sz cos
fe 0c3011 10:00:00:00:c9:cb:21:8a 8 2112 8 scr=0x3
fe 0c3010 10:00:00:00:c9:cb:5d:78 8 2112 8 scr=0x3
fe 0c300e 10:00:00:00:c9:cb:65:74 8 2112 8 scr=0x3
fe 0c300a 10:00:00:00:c9:cb:60:e8 8 2112 8 scr=0x3
fe 0c3000 20:11:00:05:33:da:02:81 8 2112 8 scr=0x0
ff 0c3011 10:00:00:00:c9:cb:21:8a 12 2048 c d_id=FFFFFC
ff 0c3010 10:00:00:00:c9:cb:5d:78 12 2048 c d_id=FFFFFC
ff 0c300e 10:00:00:00:c9:cb:65:74 12 2048 c d_id=FFFFFC
ff 0c300a 10:00:00:00:c9:cb:60:e8 12 2048 c d_id=FFFFFC
ff 0c3000 20:11:00:05:33:da:02:81 0 0 8 d_id=FFFFFA
nsshow:
N 0c3000; 3;20:11:00:05:33:da:02:81;10:00:00:05:33:da:02:81; 0x00000000
Fabric Port Name: 20:30:00:05:33:60:f9:00
Permanent Port Name: 20:11:00:05:33:da:02:81
Port Index: 48
Share Area: No
Device Shared in Other AD: No
Redirect: No
Partial: No
N 0c300a; 3;10:00:00:00:c9:cb:60:e8;20:00:00:00:c9:cb:60:e8; 0x00000003
FC4s: FCP
PortSymb: "Emulex PPN-10:00:00:00:c9:cb:60:e8"
NodeSymb: "Emulex LPe1205-CIOv FV2.01A3 DV8.2.2.126.50"
Port Index: 48
Share Area: No
Redirect: No
Partial: No
N 0c300e; 3;10:00:00:00:c9:cb:65:74;20:00:00:00:c9:cb:65:74; 0x00000003
FC4s: FCP
PortSymb: "Emulex PPN-10:00:00:00:c9:cb:65:74"
Port Index: 48
Share Area: No
Redirect: No
Partial: No
N 0c3010; 3;10:00:00:00:c9:cb:5d:78;20:00:00:00:c9:cb:5d:78; 0x00000003
FC4s: FCP
PortSymb: "Emulex PPN-10:00:00:00:c9:cb:5d:78"
Port Index: 48
Share Area: No
Redirect: No
Partial: No
N 0c3011; 3;10:00:00:00:c9:cb:21:8a;20:00:00:00:c9:cb:21:8a; 0x00000003
FC4s: FCP
PortSymb: "Emulex PPN-10:00:00:00:c9:cb:21:8a"
Port Index: 48
Share Area: No
Redirect: No
Partial: No
Anonymous
Thank you Alexy.  Once I have the port numbers I assume I can alias and zone as normal?
Valued Contributor
yes, sure. they are just WWNs seen by others like anything else. you alias them and then zone them.
Anonymous
Thank you for your help.
