Anonymous
modes on switches
Could some tell me simple and clear what different modes in SAN swicthes actually do? where it is needed and why?  Also what numeric code each mode is represnted with ( native=0?)
here are the different modes i heard about
Native mode, fabric mode, open mode and fabric legacy
External Moderator
Re: modes on switches
See the Command Reference Manual
about "interopmode" command
TechHelp24
Anonymous
i got the information from CRM for FOS 6.1.1; But CRM for FOS 7.0.0 says the interopmode command is removed/deprecated; so now what is the equivalent or what does this change means?
External Moderator
Interop-Mode is FIS 7 obsolete.
In soime circumstance you can work with IR = Integrated Routing ( in supported Plattforms )
TechHelp24
