Anonymous
iSCSI - working with FC4-16IP iSCSI blade
Anyone of you guys has worked with the Brocade 48K iscsi blade. Could you please point to manual and share what issues to avoid?
Thanks!
External Moderator
Re: iSCSI - working with FC4-16IP iSCSI blade
David,
all Manuals what you ned, are available for Download here in the Technial Resource Center.
http://www.brocadeconnect.com/brocdoc/viewSummary.jsp?cat_id=66668531
see the Command Reference Manuals, here are all iscsixxxx command, and the FabOS Administrator Guide.
Error code are listed in the Message Refrence Guide,
TechHelp24
Anonymous
TechHelp24,
Thanks for the answer. The link got me to a Fabric OS documentation page. I will drill down and see what I can find.
Thanks again.
External Moderator
David,
what kind of question / issue you have with the iscsi blade ?
TechHelp24
Anonymous
OK. Here's the situation.  At my main site I'm running 2 x 48K with 3x48-port blades. Currently each server is dual-homed with 2 sperate Emulex HBAs each. Mangement wants to start using iscsi for "low end" servers to avoid incuring the cost of the HBAs. They want to use the 2 build-in GigE NICs on te server to access the storage (HP 24K). Before purcahsing the iSCSI blade I want to have an idea about how to implement it and what the requirements are. I went to both HP and Brocade's web site but only got generic (specs) but no real-world examples. I wanted to get a hodl of the manual so I coudl start getting familiar with it. If you have any information that you could share, that would be great.
Thanks again for following up.
External Moderator
David,
here a lot of Manuals and Course for the iSCSI Blade.
Hope this help you to understandmg this iSCSI princip.
If you have another questiol. let me know.
See by Brocade iLearning Plattform, if youcan find more DOC about iSCSI.
here can you get a Course for iSCSI
http://learning.brocade.com/ilearn/en/learner/jsp/login.jsp?site=BES
TechHelp24
Anonymous
Dear TechHelp24, I think you gave me what I was looking for.  Thanks so much for the attachements and the info on the course.
