New Member
how to check what wwn was connected after a port went offline
Hi All,
Can you please help if there is command to check what wwn or device was connected on a specific port before it went offline in case i do not have supportshow.
Broadcom Moderator
Re: how to check what wwn was connected after a port went offline
Hi,
starting with FOS 7.4.x there is a command:
portloginshow [Port] -history
It will show you all recent WWN logouts.
If you are below 7.4 it will be difficult...
TL
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers. All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
Broadcom Moderator
Hi,
earlier release ((at least from 7.2) there is nsdevlog which can be used like
nsdevlog --show -port <port number>
or
nsdevlog --show -slot <slot> -port <portnumber>
