Occasional Visitor
fabric discover error for 2499-816 switches
[ Edited ]
We have 2499-816 model switches in our environment and while doing fabric discover we are getting the error "SNMP communication failed. SNMP credential may be invalid: seed switch not registered for SNMP traps "
I have did the follow settings in 2498-384 model switches and its working
1. Added INA server IP in snmp access control list of switches.
2. Added INA server IP in ipfilter table
Anyone could you please help to fix this.
Thanks in advance.
Broadcom Moderator
Re: fabric discover error for 2499-816 switches
Hi,
Do you have virtual fabrics enabled or not? If  yes, have you changed the FID for default switch from 128?
Can you post the snmp v1 pr snmp v3 which you are using for discovery, please?
