Occasional Contributor
er_type2_miss seeing these error Brocade running in AG mode
[ Edited ]
Brocade running v6.3.1_dcb5 connected to upstrem cisco MDS fabric , the fillword is set to mode 3.
Can we igonre these errors? This port is an N port (FROM BLADE chassis switch FC to Cisco FABRIC).
Broadcom Moderator
Re: er_type2_miss seeing these error Brocade running in AG mode
Hello,
In the case of a few sts_ftb_type2_miss - It is possible that when a device goes offline, the entry will be removed from the ASIC, but the inflight frames from other switches could get dropped. This is similar to unroutable/dest_unreachable frame errors when a port goes offline all of a sudden. It doesn’t indicate a problem so seeing a few of these in the logs is fine.
Does counter increment continuously?
Yes not much , but they are slowly incrementing, but I don't see any F ports ( blades ) going offline and nor the N port ( Brocade AG NPIV PORT) is offline though?
Broadcom Moderator
Do you have any issue on the concerned fabric?
Can you provide a portstatsshow of the concerned ports?
