Anonymous
down grade from v6.3.1 to 6.1.1d Help
1st time posting. I just setup a New IBM H Chassis and trying to down grade the switches from 6.3.1 to 6.1.1d so they match all the other chassis.
I have downloaded 6.2.2, 6.2.1 and still says it cant find the  -  Reached EOF of TAR file looking for release.plist
I'm new at this and figured to give this a shot while waiting for a call back from IBM. any help would be great.
Thanks
External Moderator
Re: down grade from v6.3.1 to 6.1.1d Help
see this thread about release.plist question.
http://community.brocade.com/thread/7704
--->>>I just setup a New IBM H Chassis and trying to down grade the switches from 6.3.1 to 6.1.1d so they match all the other chassis.
1) wht is the reason you want to downgrade to ?
2) is the switch you want to downgrade supported by 6.1.x ?
TechHelp24
