Anonymous
brocade 8/24 fabric with brocade 2/8 (built-in HP-MSA-1000)
Hello,
we have two brocade 8/24 having domain id 11 and 12, and have one MSA-1000 containing two controllers, each have 2/8 brocade switch. i am connecting one of the brocade 8/24 to MSA-1000 (2/8). but its not visiable to both side.
Some time it displays as  Segmented but not in fabric. here is some output of 8/24 switch. Port 5 is connected to 2/8
Switch1:admin> switchshow
switchName:     Switch1
switchType:     71.2
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   11
switchId:       fffc0b
switchWwn:      10:00:00:05:1e:86:82:e7
zoning:         ON (ConfigZone)
switchBeacon:   OFF
Area Port Media Speed State     Proto
0   0   id    N8   Online           L-Port  1 public
1   1   id    N8   Online           L-Port  1 public
2   2   id    N8   No_Light
3   3   id    N2   Online           F-Port  10:00:00:e0:02:23:1f:c8
4   4   id    N2   Online           F-Port  21:00:00:e0:8b:85:78:67
5   5   id    N2   Online           G-Port
I also changed the domain id on 2/8 brocade (MSA 1000), but still i am getting events on 8/28 switch
Time    Level    Message    Service    Number    Count    Message ID    Switch
Wed Mar 23 2011 11:13:27 GMT+00:00    Information    essd0: RTWR retry 20 to domain 2, iu_data 31000000    Switch    270    1    RTWR-1003    Switch1
Wed Mar 23 2011 11:14:39 GMT+00:00    Information    essd0: RTWR retry 24 to domain 2, iu_data 31000000    Switch    271    1    RTWR-1003    Switch1
Wed Mar 23 2011 11:15:50 GMT+00:00    Information    essd0: RTWR retry 28 to domain 2, iu_data 31000000    Switch    272    1    RTWR-1003    Switch1
Anonymous
Re: brocade 8/24 fabric with brocade 2/8 (built-in HP-MSA-1000)
Have you installed the Fabric License on each switch?
Did you if your firmware levels are supported in one fabric?
When is display segmented what's the reason given?
BTW segmented means the switch is unable to join the fabric, thus its not visible.
Are the fabric parameters of the MSA2/8 and B300 equal (like R_A_TOV etc)
Do both the MSA2/8 and B300 switches have an active configuration?
If so, did you consider the merging of fabric guidelines?
Anonymous
Hi,
Fiber licenses are already installed, how can i verify the fabric parameters? i am new in this domain need help to merg fabric.
the simple i know is that, domain id should be different on each switch
External Moderator
MSA-1000 2/8 Switch, is a Embedded Brocade 3000 Switch.
This Switch not longer Support Zoning Config with newer product like the 8/24
For details about support with 6.x FOS refer the release Notes, in the Table Notes.
TechHelp24
Anonymous
configshow -pattern fabric
will give fabric parameters
