Turn on suggestions
Showing results for
03-01-2015 12:41 AM
Dear All,
I got a little confused after setting up ISL between 2 brocade san switches. May I know should I use the same zoneset configuration between two san switches? Or I should use different zoneset? Thanks a lot
Best Regards,
Elroy
03-02-2015 04:16 PM
