Occasional Contributor
Web Tools beacon buttons do not work
When I try to turn on switch beacon or chassis beacon from SwitchExplorer Web Tools GUI button I get a message "portPeerBeacon enabled on a port: 0 in logical switch -1, Please disable it and try again". How do I clear this condition? There is no logical switch -1. I can turn on the switch or chassis beacon from the command line, so why does the GUI button not work?
Broadcom Moderator
Re: Web Tools beacon buttons do not work
Hello,
In CLI mode, you can use:
chassisbeacon 1 (for enable this) or
chassisbeacon 0 (for disable this)
Or ou can use:
switchbeacon 1 (for enable this) or
switchbeacon 0 (for disable this)
Broadcom Moderator
Looking like that all 3 commands for beacon are independent, so try to make sure that
chassisbeacon, switchbeacon and portbecon are not enable and try again with GUI.
I'm looking if I can find something more on this.
Broadcom Moderator
Does port 0 is an ISL?
PortPeerBeacon has been initiated from peer swicth for port 0?
-1 could be the wrong representation of DID that send the portPeerBeacon.
Issue portPeerBeacon --show -all on the local and peer switch connected on port 0 to see if something is enable.
Broadcom Moderator
CLI works, and WebTools doesn't work for the same element, and you're getting obtuse messaging from the switch, I'd be investigating my Java JRE version on the management server.
doc
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of mechantability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
I am getting the same error message from four switches. I am using latest Java 8 on management servers. However, I ran Web Tools GUI from an old server on the same subnet with Java 7 update 79 and got the same error. "portPeerBeacon --show -all" shows no PortPeerBeacon enabled ports on any switch. This is the first time I have worked with Brocade equipment, and it is disheartening to find things that just do not work. SwitchExplorer would not launch from Firefox. The Web Tools GUI does not let me beacon the switch.
Broadcom Moderator
Hello,
What is the FOS version installed into the switches?
During the beacon process, have you first try by CLI and then by webtools or the reverse?
Does others switches installed are working fine with webtools beacon feature?
Which tab in webtools are you using?
