Anonymous
Upgraded 4024 firmware from v5.3.0a to v6.1.0g and now get message
Now that we have updated our firmware to v6.1.0g we get a message when we goto Zone Admin.
The message states the switch DB may not contain up-to-date info and prompts me if I want to import a copy of the current configuration.  If I answer yes then my Aliases are wiped out.  If I answer No then things appear to work fine.
Is this message normal?
TIA,
Josh
Anonymous
Re: Upgraded 4024 firmware from v5.3.0a to v6.1.0g and now get message
Did you get any help from Brocade Support on this ???? We are upgrading FOS next month and I would like to know if you there are any gotchas.
Thanks in advance
Anonymous
I am working with support now.  They have escalated it.  I will post the results.
External Moderator
Before your Upgrade a Blade Switch 4024 from any FabOS 5.3.0 letter or lower, to FabOS 6.x, must first Upgrade to any FabOS 5.3.1 or 5.3.2, then to FabOS 6.
The reason is a Bug in a FabOS 5.3.0 Letter.
TechHelp24
Anonymous
The upgrade isn't the problem, I know that.  I did the upgrade in two steps.
I want to know if someone has seen that warning before.
Anonymous
HP Support has not been helpful.  I have done some research and I'm wondering if this is an issue with my setup (Brocade connected to McData in Interopmode 2 running 6.1.0g) and RSCNs)
Here is why I think this.
I started with the release notes for the latest firmware version (6.2.0a)
Release Notes: (Search for "SW_RSCN")
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=3709945&prodSeriesId=3185340&swItem=co-68016-1&prodNameId=3185341&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0#im_support_23
http://www.cisco.com/en/US/products/ps5989/products_configuration_guide_chapter09186a0080664c77.html#wp1162236
TIA
Josh
Anonymous
Sorry, posted this twice because I am having issues with it.
TIA
Josh
External Moderator
Josh
you wrote here search for rw_rscn
I read carefully the release note v6.2.0a and v6.2.0b but cannot find any impact with SW_RSCN
where is that written
TechHelp24
Anonymous
Thank you for your reply,
I actually had more info in the post but it doesn't appear to populate properly
for some reason.
In the release notes it says that "SW_RSCNs for RSCNs generated by attached
nodes are not being handled in McDATA Mode." this is fixed in 6.2.0a.
I googled RSCN and came up with this definition:
"The Registered State Change Notification (RSCN) is a Fibre Channel service
that informs hosts about changes in the fabric."
If the SW_RSCNs are not handled properly couldn't that be a cause of the error
message on my Brocade switch?  If the switch thinks that the fabric has changed
but it doesn't know what changed that seems to fit the message.
I don't know for sure, I'm thinking out loud here hoping for something to spark.
TIA
Josh
External Moderator
Josh
i am a little confused
Is the switch configured in IM 2 or 3 also McDATA Mode?
TechHelp24
