Turn on suggestions
Showing results for
02-05-2019 02:18 AM
Hello,
where can i find the actual Target Path Selection Guide?
Best Regards
Patrik
02-05-2019 07:16 AM - edited 02-05-2019 07:16 AM
go to https://portal.broadcom.com/group/support/home - you should be logged in instantly if you are logged into the Broadcom Support Community. If not login.
Go to the Docs Icon and then search for Target Path Selection Guide. You will see four documents come up to download. Download away - if you do not see these documents, we will have to find out why you account is not provisioned.
02-05-2019 09:28 AM - edited 02-05-2019 09:36 AM
Hi when I search I only get one link for network advisor. I have Brocade Switches on 7.41D should I be upgrading them?
I need this documentation pleasePlease attach to this post if you can because it doesn't show up for me when I search and any direct links do not work for me.
Thank you.
