Anonymous
Accepted Solution
Speed Mismatch / Incompatible SFP Brocade 2498
Hello, since we've installed new SFP, switch shows error
http://i.imgur.com/utSnEkf.jpg
http://i.imgur.com/Pp2T5XG.jpg
Firstly I thought it's because firmware version which was 6.1. But I did upgrade up to 7.2 and nothing changed.
Is this error serious? Can we leave it like this? Maybe the vendor is wrong, please help.
Frequent Contributor
Re: Speed Mismatch / Incompatible SFP Brocade 2498
[ Edited ]
according to your pictures you inserted 8gbps sfps into your switch that are not brocade labeled, that means it wont work, brocade limited the use of sfps from other vendors.
see this post
http://community.brocade.com/t5/Fibre-Channel-SAN/use-non-brocade-branded-Sfp/td-p/62864
and many other on this forums dealing with the same issue.
in short
8gpbs plattform uses only brocade sfps.
ibm system storage solutions handbook
read the grey box beneath the picutere on page 417
Anonymous
Thank you so much for replay, its looks like we need order new SFTP.
