Anonymous
Setting up IPsec for FCIP
Hi,
Recently, when I tried to configure IPsec over FCIP, I noticed that I couldn't execute the command " policy –create type number "  It mentions " command not supported on this platform " When I check the license, I do have the 'High Performance Extension over FCIP/FC license' installed. Any idea? Thanks..
External Moderator
Re: Setting up IPsec for FCIP
--->>> It mentions " command not supported on this platform "
Some command are Plattforms specific Command, and are not available for all Brocade Plattforms.
Now is a question, what kindof Plattform you try to execute the command ?
TechHelp24
Anonymous
Hi Techhelp,
The platform that I am using is the Brocade 7800 Series. I've checked the Fabric OS FCIP Administrator Guide and there's command associated with that for this platform. The Fabric OS version that I am running is v 6.4. Attached is the FCIP admin guide.
Anonymous
Hi,
Any idea on the above issue? Thanks.
