Occasional Contributor
Segmented Switch after removing a switch from fabric
Hello.
We had 2 fabrics with each 3 switches. We decomissioned the third switch and now have 2 switches / fabric.
Now we have the "Segmented switch" status in the GUI. (See attachment)
Is there any way to get rid of this without any downtime?
External Moderator
Re: Segmented Switch after removing a switch from fabric
@Sebastiaan
how the removed switch was connected / ISL - to ?
cascade or mesh ?
befor decomiss, did you check if the switch was set as subordinate or principal ?
TechHelp24
Hello Antonio,
The switch was subordinate, I am pretty sure.
It was Mesh topology.
Frequent Contributor
Are you using BNA? Accept Fabric changes.
We are not using BNA at this moment.
hypothetically speaking, let's say the switch was indeed principal.
how would I go about clearing the segmented switch from the gui?
External Moderator
whit or without, BNA don't resolved the problem and is not a solution.
second, in a small SAN Environments make absolutely no sense to create a Fabric as Mesh, Brocade best practicies is Cascade.
in feew word, it is not easy to remove / decomissioned a switch from a Mesh Fabric, in you case I would suggest - I don't know you config -  to reconnect the switch in order to review the config.
then, the best solution is to disconnect another member switch from a Fabric, create a New config and move all path to.
finally disconnect the second Prod. switch and ISL in order to create a New Fabric.
BTW about Mesh Design, the best practices is at least of 4* Switches.
TechHelp24
Hey Antonio,
Thanks for your reply.
So basically there is no way to get rid of this?
We cannot just decomission a production switch... Can this "Segmented status" cause any impact
on production in the future?
External Moderator
@Sebastiaan
you can try to rebuild a Fabric, see this Threads for some details
https://community.brocade.com/t5/Fibre-Channel-SAN/More-detail-about-fabric-rebuild/td-p/92695
TechHelp24
[ Edited ]
I've already tried this on an old switch that had the same problem and it did not solve this issue sadly.
I'm just wondering if this can prove troublesome in the future or will this never have any impact on the fabric?
